What do the monthly costs of the Zendure electricity tariff consist of?
The monthly Zendure electricity price includes the following components:
Monthly basic fee
Monthly grid and metering point fees (dependent on postal code, see contract confirmation)
Exchange electricity price (+ additional price components) in ct/kWh * monthly consumption
Related Articles
How does the switching process to the Zendure electricity tariff work?
You register via the application flow, and we take care of the rest. After concluding the tariff, you automatically receive an order confirmation from us by email. Following that, we cancel your contract with your current electricity provider and ...
Do I need an intelligent metering system (smart meter) in order to use the dynamic tariff?
No. Our tariff generally supports all common meter types. However, in order to fully realize the potential of a dynamic tariff through intelligent consumption, a smart meter is required. You can easily apply for installation via Zendure. A smart ...
What is the price difference between tariffs with fixed vs. dynamic electricity prices?
Fixed-price tariffs are usually more expensive in the long term, because the supplier adds a margin to the purchase price and intelligent electricity consumption is not rewarded. Dynamic electricity tariffs pass through the exchange electricity price ...
How does the "Negative Electricity Price" logic work?
When negative electricity prices are detected, loads are activated in descending order of device priority to fully utilize favorable market conditions, maximize electricity consumption, and reduce electricity costs.
Who can I contact if I have questions about my electricity tariff?
If you have questions, feel free to contact Zendure Support directly, for example via the Zendure customer portal or the Zendure app.
Popular Articles
How to use Smart CT Mode
Recent Articles
