What is the price difference between tariffs with fixed vs. dynamic electricity prices?
Fixed-price tariffs are usually more expensive in the long term,
because the supplier adds a margin to the purchase price and intelligent electricity consumption is not rewarded.
Dynamic electricity tariffs pass through the exchange electricity price and therefore create incentives to
consume more at cheaper times.
So this not only means that a dynamic electricity tariff is cheaper in the long term, but also that with smart
consumption (through a heat pump, solar, wallbox), significant additional costs can be saved.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
    • Recent Articles
    • Important Checks Before Connecting PV Modules
      Before connecting PV modules, please verify the following items to ensure safe and stable operation of the unit: PV module specifications (e.g., open-circuit voltage Voc) are within the permissible operating range of the device. Each PV input (MPPT) ...
    • Important Checks Before Connecting PV Modules:
    • Will SolarFlow 800 Pro 2 supply power during a power outage?
      According to EU safety regulations, the SolarFlow 800 Pro 2 will stop supplying power to the grid during a power outage; However, you can use the off-grid outlet during power outage with max 1000W power.
