How does the "Negative Electricity Price" logic work?
When negative electricity prices are detected, loads are activated in descending order of device priority to fully utilize favorable market conditions, maximize electricity consumption, and reduce electricity costs.
Related Articles
What is the price difference between tariffs with fixed vs. dynamic electricity prices?
Fixed-price tariffs are usually more expensive in the long term, because the supplier adds a margin to the purchase price and intelligent electricity consumption is not rewarded. Dynamic electricity tariffs pass through the exchange electricity price ...
Which core logics does Zendure HEMS primarily follow for load control?
Four core logics: Usage Plan, Surplus Energy, Negative Electricity Price, and Dynamic Load Management. These logics work together to balance demand, costs, PV utilization, and electrical safety.
What do the monthly costs of the Zendure electricity tariff consist of?
The monthly Zendure electricity price includes the following components: Monthly basic fee Monthly grid and metering point fees (dependent on postal code, see contract confirmation) Exchange electricity price (+ additional price components) in ct/kWh ...
How does the switching process to the Zendure electricity tariff work?
You register via the application flow, and we take care of the rest. After concluding the tariff, you automatically receive an order confirmation from us by email. Following that, we cancel your contract with your current electricity provider and ...
I submitted my meter reading, how does the correction work?
As long as no smart meter is installed, we use your meter reading as the basis for billing. If the meter reading reaches us by the 1st day of the following month, it is directly taken into account for the current monthly bill. Otherwise, billing is ...
Popular Articles
How to use Smart CT Mode
Recent Articles
