How to add a Tesla to HEMS?
1. On the HEMS page, tap the 【Settings】 icon in the upper right corner to enter the 【Home Settings】 page.
2. Tap 【Device Management 】under 【General Settings】.
3. Tap 【Add Appliances 】in【Select Appliance】, check the Tesla vehicle in the device selection list, and save the settings.
Related Articles
How to set the usage schedule for Tesla on Zendure?
1. On the HEMS page, tap 【Home】and enter 【Home Settings】,then select 【Load Control】to access the page. 2. Tap 【Load Settings】, select Tesla in the load type, find 【Usage Plan】 in the load configuration, and tap 【Add Time Schedule】. 3. A setting ...
How to authorize and connect a Tesla vehicle to the Zendure APP?
1. Tap the Tesla icon in the Zendure APP. 2. After confirming that the vehicle meets the version requirements on the reminder page (Vehicle version requirements: The vehicle must run on firmware version 2024.26 or higher; applications configured with ...
How to allow HEMS to control smart plugs?
Enable the "Turn on/off load control to allow HEMS control" option in the smart plug settings to permit HEMS to perform load control.
How to authorize and add Shelly's relay to the Zendure APP?
1. On the 【Profile】 page, click the 【Shelly】 icon, jump to the embedded page for authorizedlogin, then click【Add Device】, select the Shelly relay that needs to be authorized to control the heat pump,and click Confirm to add. 2. After returning to the ...
Can I manually control devices controlled by HEMS?
Yes, you can. For example, you can manually click "Charge Now" or "Stop Charging" on the Tesla details page, and smart plugs can be manually controlled via the APP switch. Manual operations will temporarily override the system's automatic scheduling.
Popular Articles
How to use Smart CT Mode
Recent Articles
