How to authorize and connect a Tesla vehicle to the Zendure APP?
1. Tap the Tesla icon in the Zendure APP.
2. After confirming that the vehicle meets the version requirements on the reminder page (Vehicle version requirements: The vehicle must run on firmware version 2024.26 or higher; applications configured with the old certificate signing process require firmware version 2023.20.6 or higher; Currently, support for adding Model Y and Model 3 vehicles is available.), jump to the Tesla embedded page and log in to your Tesla account.
3. Check all authorization options (it is recommended to select all to avoid functional restrictions), and you will be redirected back to the “Authorization successful !” page of the Zendure APP upon completion.
4. After successful authorization, select the vehicle to be added and the prompt 【Confirm Add】will appear.
5. Return to the device list page, where 【Unauthorized 】is displayed below the current vehicle model. Tap Tesla and a pop-up will appear asking "Allow third-party access to your vehicle?".
6. Tap【 Confirm Signing the agreement 】to complete the authorization.
7. Return to the list, and the current connection status will be displayed below the vehicle model, with the battery level and charging power shown above it.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
    • Recent Articles
    • Important Checks Before Connecting PV Modules
      Before connecting PV modules, please verify the following items to ensure safe and stable operation of the unit: PV module specifications (e.g., open-circuit voltage Voc) are within the permissible operating range of the device. Each PV input (MPPT) ...
    • Important Checks Before Connecting PV Modules:
    • Will SolarFlow 800 Pro 2 supply power during a power outage?
      According to EU safety regulations, the SolarFlow 800 Pro 2 will stop supplying power to the grid during a power outage; However, you can use the off-grid outlet during power outage with max 1000W power.
