Can I manually control devices controlled by HEMS?
Yes, you can. For example, you can manually click "Charge Now" or "Stop Charging" on the Tesla details page,
and smart plugs can be manually controlled via the APP switch. Manual operations will temporarily override the
system's automatic scheduling.
Related Articles
How are devices connected to smart plugs controlled?
Ensure devices operate within the configured allowed time window and meet the minimum operating time requirements. Start and stop times are dynamically determined based on electricity prices, PV availability, energy storage, and household power ...
How to set priorities between different devices, and what impact does this have on load control?
Set priorities for devices in the HEMS settings; the system activates devices in "high→low" priority order and turns off devices in "low→high" priority order. High-priority devices are activated first and turned off last.
How to allow HEMS to control smart plugs?
Enable the "Turn on/off load control to allow HEMS control" option in the smart plug settings to permit HEMS to perform load control.
What functions of Tesla can the Zendure system control?
In the "Ready for Charge" state, you can manually start charging; during charging, you can manually stop charging.
Popular Articles
How to use Smart CT Mode
Recent Articles
