How to set the usage schedule for Tesla on Zendure?
1. On the HEMS page, tap 【Home】and enter 【Home Settings】,then select 【Load Control】to access the page.
2. Tap 【Load Settings】, select Tesla in the load type, find 【Usage Plan】 in the load configuration, and tap 【Add Time Schedule】.
3. A setting window will pop up with the default usage time: 08:00-22:00, cycle from Monday to Friday. Users can set the start and end usage time and the corresponding applicable dates respectively according to personal needs later.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
