How to allow HEMS to control smart plugs?
Enable the "Turn on/off load control to allow HEMS control" option in the smart plug settings to permit HEMS to perform load control.
Related Articles
How to use Smart Matching Mode
Smart Matching Mode is a Cloud-base feature, so you need to keep the SolarFlow and the ‘sensor’ devices have stable Wi-Fi connections all the time. Smart Matching Mode Introduce the function of Smart Matching Mode and its advantages and ...
How to use Smart CT Mode
Will it affect load control if Tesla vehicles, heat pumps, or smart plugs go offline?
Yes, it will. When a device is offline, the system will not include that device in load control when refreshing the plan.
Can I manually control devices controlled by HEMS?
Yes, you can. For example, you can manually click "Charge Now" or "Stop Charging" on the Tesla details page, and smart plugs can be manually controlled via the APP switch. Manual operations will temporarily override the system's automatic scheduling.
How does a smart meter work?
A smart meter can monitor the household’s total electricity consumption and the direction of current in real time. When household power demand increases, it automatically raises the discharging power; when demand decreases, it lowers the output. This ...
Popular Articles
Recent Articles
