I submitted my meter reading, how does the correction work?
As long as no smart meter is installed, we use your meter reading as the basis for billing.
If the meter reading reaches us by the 1st day of the following month, it is directly taken into account for the current monthly bill. Otherwise, billing is initially based on an estimate. This estimate is based on the annual consumption you specified when you concluded the contract. As soon as your meter reading is available, billing is automatically corrected in the next monthly bill.
We estimate your quarter-hour consumption according to an established standard (standard load profile of the Federal Network Agency) and offset it against the exchange electricity price in order to determine a weighted average price for you.
Related Articles
Why am I being asked for my meter reading?
If you do not yet have a smart meter, you will be billed according to the standard load profile (SLP). For this billing, we need your electricity consumption and therefore periodically a current meter reading. If we do not have the meter reading, we ...
Which smart meters can SolarFlow 2400 Pro work with?
It can work with Zendure Smart Meter 3CT, Smart Meter D0/P1, Shelly Pro 3EM, Shelly 3EM, Everhome Ecotracker IR, enabling automatic power adjustment.
Which smart meters can SolarFlow 1600 AC+ work with?
Which smart meters can SolarFlow 2400 AC+ work with?
How does a smart meter work?
A smart meter can monitor the household’s total electricity consumption and the direction of current in real time. When household power demand increases, it automatically raises the discharging power; when demand decreases, it lowers the output. This ...
Popular Articles
How to use Smart CT Mode
Recent Articles
