What is the "household tripping current threshold", and how should I set it?
It refers to the rated tripping current of the main house circuit breaker and should be set according to the actual rated value. HEMS will ensure that the total household load power consumption is below this threshold, balancing energy efficiency and electrical safety.
Popular Articles
How to use Smart CT Mode
Recent Articles
