How does the Zendure PowerHub 3P enable whole-home off-grid backup on the main line?
1. In a three-phase power system, install the PowerHub after the main switch in the distribution panel so that all household power passes through it. Install a new breaker after the PowerHub with a rated current ≤ the main switch rating to prevent output current from exceeding the circuit capacity.
2. Only phases connected to a SolarFlow 4000 Mix Pro/AC+ support off-grid backup.
Examples:
(1) With a SolarFlow 4000 Mix Pro on L1, only L1 supports backup; L2 and L3 do not.
(2) With units on L1 and L2, only L1 and L2 support backup; L3 does not.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
