What is the operating ambient temperature range of the Zendure PowerHub 3P?
The operating temperature must be between -20℃ and 55℃. Excessively high or low temperatures will affect the tripping characteristics of the circuit breaker and may cause premature tripping at currents below 63A.
Popular Articles
How to use Smart CT Mode
Recent Articles
