What is the current official support for heat pumps announced by Zendure?
At present, we support heat pumps compatible with SG ready, but the tests only cover two models of heat pumps:
Viessmann Vitocal 250ah/Vaillant arotherm Plus. We do not guarantee complete functional effects for other heat pumps.
Related Articles
What are the necessary hardware conditions for realizing the heat pump function?
1、CT for monitoring the heat pump: 1 Zendure proprietary CT or 2 Shelly CTs (Shelly Pro 3EM and Shelly 3EM). 2、Relay for controlling the heat pump (model: Shelly Pro 2 or Shelly Plus 2PM).
How is the operation of heat pumps controlled?
Operation periods are planned to ensure hot water/heating needs are met before the user-defined usage period. Combined with energy prices, battery status, PV, and grid conditions, operations are shifted to the most economical periods without ...
How to authorize and connect a Tesla vehicle to the Zendure APP?
1. Tap the Tesla icon in the Zendure APP. 2. After confirming that the vehicle meets the version requirements on the reminder page (Vehicle version requirements: The vehicle must run on firmware version 2024.26 or higher; applications configured with ...
Will it affect load control if Tesla vehicles, heat pumps, or smart plugs go offline?
Yes, it will. When a device is offline, the system will not include that device in load control when refreshing the plan.
Popular Articles
How to use Smart CT Mode
Recent Articles
