Key precautions for SR adapter cable:
  1. Stripping length: 6–9mm. Strip the wire end with a wire stripper to expose L, N, PE copper conductors.
  2. Crimp each wire core into cold-pressed terminals respectively and compress tightly with a crimping tool.
  3. Pass the cable through the cable gland of SR fitting. Fully insert stripped L, N, PE wire cores into corresponding terminals to the bottom, fasten with screws. Perform pull test after crimping to ensure no looseness.
  4. Push the crimped terminals into the connector housing; a click sound indicates proper locking.
  5. Tighten the connector and lock nut.
    • Related Articles
    • Key precautions for SR adapter cable:
      Stripping length: 6–9mm. Strip the wire end with a wire stripper to expose L, N, PE copper conductors. Crimp each wire core into cold-pressed terminals respectively and compress tightly with a crimping tool. Pass the cable through the cable gland of ...
    • Key precautions for manufacturing and connection of the earth wire:
      1.Manufacture the external earth cable: Confirm terminal specification 8.4≤D≤12.5mm. Cut the cable according to the size of O-type terminal length +3mm, insert heat shrink tubing onto the cable and strip the insulation. 2.Insert the wire core into ...
    • Winter Equipment Operation Precautions:
      1. Keep equipment dry and avoid low-temperature frost; 2. Regularly check cable connections and waterproof performance; 3. If shut down for extended periods, recharge once every 2–3 months.
    • Winter operation precautions:
      - Keep the device dry and avoid frost or freezing conditions. - Regularly check cable connections and waterproofing. - If the device is unused for a long period, it is recommended to recharge it every 2–3 months.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
