Key precautions for manufacturing and connection of the earth wire:
1.Manufacture the external earth cable: Confirm terminal specification 8.4≤D≤12.5mm. Cut the cable according to the size of O-type terminal length +3mm, insert heat shrink tubing onto the cable and strip the insulation.
2.Insert the wire core into the cold-pressed terminal and crimp tightly with a crimping tool to ensure firm connection.
3.Move the heat shrink tubing to fully cover the joint between terminal and cable. Heat evenly with a heat gun until the tubing fully shrinks. Check sealing after cooling; production is completed.
4.Install the connector with O-type terminal onto the product earth terminal.
Before connecting to the distribution box, always wear insulating gloves before opening the distribution box.
5.Turn off the circuit breaker, connect the other end of the earth wire to the earth busbar of the distribution box, then tighten with M6 screws, installation completed.
    • Related Articles
    • Key precautions for manufacturing and connection of the earth wire:
      1.Manufacture the external earth cable: Confirm terminal specification 8.4≤D≤12.5mm. Cut the cable according to the size of O-type terminal length +3mm, insert heat shrink tubing onto the cable and strip the insulation. 2.Insert the wire core into ...
    • Key precautions for SR adapter cable:
      Stripping length: 6–9mm. Strip the wire end with a wire stripper to expose L, N, PE copper conductors. Crimp each wire core into cold-pressed terminals respectively and compress tightly with a crimping tool. Pass the cable through the cable gland of ...
    • Does it support self-installed grid connection?
      The SF2400 Pro supports plug-and-play, user-installed grid connection. If you want to connect this product as a non-plug-and-play device to the distribution board to participate in feed-in tariff settlement, a certified electrician must hard-wire it ...
      The SF2400 AC+ supports plug-and-play, user-installed grid connection. If you want to connect this product as a non-plug-and-play device to the distribution board to participate in feed-in tariff settlement, a certified electrician must hard-wire it ...
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
