Winter Equipment Operation Precautions:
1. Keep equipment dry and avoid low-temperature frost;
2. Regularly check cable connections and waterproof performance;
3. If shut down for extended periods, recharge once every 2–3 months.
Related Articles
Winter operation precautions:
- Keep the device dry and avoid frost or freezing conditions. - Regularly check cable connections and waterproofing. - If the device is unused for a long period, it is recommended to recharge it every 2–3 months.
What is the minimum continuous operation time?
5 minutes by default (not configurable by users). The minimum operation time means that once the vehicle starts charging, it must run continuously for at least 5 minutes before it can be stopped, so as to avoid equipment damage caused by frequent ...
What are the requirements for enabling offline local operation?
Before enabling offline local operation, make sure the following requirements are met: 1) A home HEMS system has been created 2) PowerHub has been successfully added to the home HEMS system 3) All relevant devices in the system have been upgraded to ...
How is the operation of heat pumps controlled?
Operation periods are planned to ensure hot water/heating needs are met before the user-defined usage period. Combined with energy prices, battery status, PV, and grid conditions, operations are shifted to the most economical periods without ...
Popular Articles
How to use Smart CT Mode
Why is my Hub’s battery light(AB1000 LED) turned off even though I have a battery connected to it?
Check the battery status page of the Zendure App to see if all your connected batteries are recognized by the system. If no batteries are recognized, please contact support@zendure.com for further assistance. Please include a picture of the Zendure ...
Recent Articles
EVFlow AC Installation Official Tutorial Video
EVFlow AC Official Video installation link: https://www.youtube.com/watch?v=QQ4JOUNW-30
What is EVFlow AC?
EVFlow AC is a smart AC home EV charger provide 3 versions (7.4 kW, 11 kW, and 22 kW) When integrated with Zendure HEMS 2.0,it coordinates solar power, home energy storage, electricity tariffs, and household load management to optimize EV charging.
How should I clean and maintain EVFlow AC
Inspect the charger, charging cable, and connectors for wear or damage approximately every six months. Before cleaning, disconnect the upstream power supply. Use a soft, slightly damp cloth to clean the enclosure. Do not use high-pressure water jets, ...
What should I do if charging does not start after plugging in the connector or the red fault indicator appears?
First, check the following: Ensure the charging connector is fully inserted. Confirm that charging authorization has been completed. Check whether the vehicle or Zendure App has an active charging schedule limit. Verify that the selected charging ...
How can I identify the device status from the indicator light?
Under normal operating conditions, green indicates online status, while blue indicates offline status. A solid light indicates standby mode, while a breathing light indicates that charging is in progress. When the breathing light changes to a solid ...
