Winter operation precautions:
- Keep the device dry and avoid frost or freezing conditions.
- Regularly check cable connections and waterproofing.
- If the device is unused for a long period, it is recommended to recharge it every 2–3 months.
Related Articles
- Keep the device dry and avoid frost or freezing conditions. - Regularly check cable connections and waterproofing. - If the device is unused for a long period, it is recommended to recharge it every 2–3 months.
Winter Equipment Operation Precautions:
1. Keep equipment dry and avoid low-temperature frost; 2. Regularly check cable connections and waterproof performance; 3. If shut down for extended periods, recharge once every 2–3 months.
What is the minimum continuous operation time?
5 minutes by default (not configurable by users). The minimum operation time means that once the vehicle starts charging, it must run continuously for at least 5 minutes before it can be stopped, so as to avoid equipment damage caused by frequent ...
How is the operation of heat pumps controlled?
Operation periods are planned to ensure hot water/heating needs are met before the user-defined usage period. Combined with energy prices, battery status, PV, and grid conditions, operations are shifted to the most economical periods without ...
Safety operation requirements after connecting devices to the Schuko sockets of the Zendure PowerHub 1P
After inserting the device, fasten and tighten the safety locking latch to prevent accidental removal during operation, which could pose an electric shock hazard.
Popular Articles
How to use Smart CT Mode
