How to start the heat pump in load scheduling?
The user must complete the addition of the load devices to be scheduled in the App
and add the power consumption plan for the added devices. If only the devices are
added but no power consumption plan is added, the load scheduling cannot be started.
Related Articles
Can the control be completed if my Tesla and heat pump are not under the same electric meter?
The main CT must be connected to the main electric box, and the sub electric box can be connected to the sub CT. However, the circuits of the Tesla and the heat pump must eventually converge to the main electric box. If they are two completely ...
My Tesla and heat pump are not under the same electric meter, can the control be completed?
The main CT must be connected to the main electric box, and the sub electric box can be connected to the sub CT. However, the circuits of Tesla and the heat pump must finally converge to the main electric box. If they are two completely different ...
How to set the usage plan of the heat pump?
1. On the Hems interface, click 【Home】 to enter 【Home Settings】, and select 【Load Control】 to enter the page. 2. Then click 【Load Settings】, find 【Usage Plan】 in the load configuration and click 【Add Time Plan】. 3. A setting window will pop up, the ...
Where can I view the load scheduling plan generated by HEMS?
After all settings are completed, view the estimated load operation time (i.e., scheduling plan) on the relevant page of the Zendure APP.
What are the necessary hardware conditions for realizing the heat pump function?
1、CT for monitoring the heat pump: 1 Zendure proprietary CT or 2 Shelly CTs (Shelly Pro 3EM and Shelly 3EM). 2、Relay for controlling the heat pump (model: Shelly Pro 2 or Shelly Plus 2PM).
Popular Articles
How to use Smart CT Mode
Recent Articles
