How is the charging of Tesla vehicles controlled?
Charging is scheduled based on electricity prices, energy storage, PV, and grid status to ensure the target SOC (State of Charge) is reached before the user's planned departure time, minimizing charging costs. When other scheduling or safety logics are triggered, the charging power and time are dynamically adjusted.
Popular Articles
How to use Smart CT Mode
Recent Articles
