What are the statuses of a Tesla vehicle on the Zendure system?
- Unauthorized: The vehicle has not been authorized with a Tesla virtual key.
- Disconnected: The vehicle is not connected to an EV charger.
- Ready to Charge: The charging plug is connected and charging is available at any time.
- Charging: The vehicle is being charged.
- Charging Complete: The charging session has ended and the plug is still connected.
- Offline: The vehicle is offline.
Popular Articles
How to use Smart CT Mode
Recent Articles
