Can I set the "required runtime for each startup" for smart plugs?
Yes, set "Runtime required for each startup" in the Zendure APP to ensure the device operates for a sufficient duration after startup to achieve the expected effect.
Related Articles
How to use Smart Matching Mode
Smart Matching Mode is a Cloud-base feature, so you need to keep the SolarFlow and the ‘sensor’ devices have stable Wi-Fi connections all the time. Smart Matching Mode Introduce the function of Smart Matching Mode and its advantages and ...
How to use Smart CT Mode
How to allow HEMS to control smart plugs?
Enable the "Turn on/off load control to allow HEMS control" option in the smart plug settings to permit HEMS to perform load control.
How to add Smart Meter 3CT to the Zendure APP?
Prerequisite for successful addition in the Zendure APP: having a Zendure Smart 3CT. 1. Open the APP, enter the device list, the 【Device Selection】 page will display the searching for devices, and then jump to 【Reset Wi-Fi】. 2. The page prompts to ...
How are devices connected to smart plugs controlled?
Ensure devices operate within the configured allowed time window and meet the minimum operating time requirements. Start and stop times are dynamically determined based on electricity prices, PV availability, energy storage, and household power ...
Popular Articles
Recent Articles
