How are devices connected to smart plugs controlled?
Ensure devices operate within the configured allowed time window and meet the minimum operating time requirements. Start and stop times are dynamically determined based on electricity prices, PV availability, energy storage, and household power conditions to minimize energy costs while meeting system constraints.
Popular Articles
How to use Smart CT Mode
Recent Articles
