How to add Smart Meter 3CT to the Zendure APP?
Prerequisite for successful addition in the Zendure APP: having a Zendure Smart 3CT.
1. Open the APP, enter the device list, the 【Device Selection】 page will display the searching for devices, and then jump to 【Reset Wi-Fi】.
2. The page prompts to press and hold the IOT button for 3 seconds until the Wi-Fi indicator flashes rapidly. After completion, check 【Confirm that the Wi-Fi indicator is flashing】and click "Next".
3. Return to 【Select equipment 】, the newly addable Smart CT will be displayed, click the Smart CT to enter the 【Configuration Wi-Fi network】page.
4. After the network configuration is completed, click 【Next】, the addition success interface will appear, and click 【Initialization Settings】 below.
5. Install the clamp on the heat pump circuit, and set the monitoring type of the sub-phase on the 【Initialization Settings】 page of the APP accordingly.
    • Related Articles
    • How to use Smart CT Mode
    • How to use Smart Matching Mode
      Smart Matching Mode is a Cloud-base feature, so you need to keep the SolarFlow and the ‘sensor’ devices have stable Wi-Fi connections all the time. Smart Matching Mode Introduce the function of Smart Matching Mode and its advantages and ...
    • How to authorize and add Shelly's Smart CT to the Zendure APP?
      1. On the 【Profile】 page, click the 【Shelly】 icon, jump to the embedded page, then click 【Authorize】, and log in to the Shelly account for authorization. 2. After successful authorization, jump back to the 【Device Selection】interface and select the ...
    • How to authorize and add Shelly's relay to the Zendure APP?
      1. On the 【Profile】 page, click the 【Shelly】 icon, jump to the embedded page for authorizedlogin, then click【Add Device】, select the Shelly relay that needs to be authorized to control the heat pump,and click Confirm to add. 2. After returning to the ...
    • SolarFlow 2400 Pro Installation Manual
      Video link: EN: https://www.youtube.com/watch?v=X307oOWnYZI DE: https://www.youtube.com/watch?v=7qATOYRR6Bc FR: https://www.youtube.com/watch?v=N3cQ1WDFSI0 NL: https://www.youtube.com/watch?v=PAbmGMwHOh8
    • Popular Articles
    • Warranty Terms & Conditions (US)
