How to set priorities between different devices, and what impact does this have on load control?
Set priorities for devices in the HEMS settings; the system activates devices in "high→low" priority order and turns off devices in "low→high" priority order. High-priority devices are activated first and turned off last.
Related Articles
How is the load control plan generated?
The system automatically generates it based on user-set device parameters, usage plans, priorities, household tripping current thresholds, as well as real-time and predicted electricity prices, solar power generation, battery status, and grid ...
How to set the usage schedule for Tesla on Zendure?
1. On the HEMS page, tap 【Home】and enter 【Home Settings】,then select 【Load Control】to access the page. 2. Tap 【Load Settings】, select Tesla in the load type, find 【Usage Plan】 in the load configuration, and tap 【Add Time Schedule】. 3. A setting ...
How to set the usage plan of the heat pump?
1. On the Hems interface, click 【Home】 to enter 【Home Settings】, and select 【Load Control】 to enter the page. 2. Then click 【Load Settings】, find 【Usage Plan】 in the load configuration and click 【Add Time Plan】. 3. A setting window will pop up, the ...
Will it affect load control if Tesla vehicles, heat pumps, or smart plugs go offline?
Yes, it will. When a device is offline, the system will not include that device in load control when refreshing the plan.
How to start the heat pump in load scheduling?
The user must complete the addition of the load devices to be scheduled in the App and add the power consumption plan for the added devices. If only the devices are added but no power consumption plan is added, the load scheduling cannot be started.
Popular Articles
How to use Smart CT Mode
Recent Articles
