Why am I being asked for my meter reading?
If you do not yet have a smart meter, you will be billed according to the standard load profile (SLP). For this billing, we need your electricity consumption and therefore periodically a current meter reading. If we do not have the meter reading, we use the annual consumption forecast you provided when you concluded the electricity tariff in order to be able to calculate a monthly advance payment for you.
Related Articles
I submitted my meter reading, how does the correction work?
As long as no smart meter is installed, we use your meter reading as the basis for billing. If the meter reading reaches us by the 1st day of the following month, it is directly taken into account for the current monthly bill. Otherwise, billing is ...
Do I need an intelligent metering system (smart meter) in order to use the dynamic tariff?
No. Our tariff generally supports all common meter types. However, in order to fully realize the potential of a dynamic tariff through intelligent consumption, a smart meter is required. You can easily apply for installation via Zendure. A smart ...
How does a smart meter work?
A smart meter can monitor the household’s total electricity consumption and the direction of current in real time. When household power demand increases, it automatically raises the discharging power; when demand decreases, it lowers the output. This ...
Popular Articles
How to use Smart CT Mode
Recent Articles
