When connecting directly to a household distribution box, what type of circuit breaker should be installed in the box?What specification of wire should be used?
A circuit breaker with a rated current of no less than 32A must be installed and select cables with a cross-sectional area of ≥6mm².
Popular Articles
How to use Smart CT Mode
Recent Articles
