Does it support self-installed grid connection?
The SF2400 Pro supports plug-and-play, user-installed grid connection.
If you want to connect this product as a non-plug-and-play device to the
distribution board to participate in feed-in tariff settlement, a certified
electrician must hard-wire it to a new circuit breaker and register it in MaStR
as a non-plug-and-play storage inverter.
Popular Articles
How to use Smart CT Mode
Recent Articles
