What is the off-grid backup switching speed of the Zendure PowerHub 1P, and what prerequisites are required?
It supports fast off-grid backup switching at the 20ms level. The prerequisite is that at least one SolarFlow 4000 Mix Pro/AC+ energy storage device is connected.
Popular Articles
How to use Smart CT Mode
Recent Articles
