What are the parameters and functions of the inverter breakers and main breaker of the Zendure PowerHub 3P?
1. Inverter breakers: 3×32A breakers are provided. For hardwired inverters >3680W, the cables must be connected to the terminals below the corresponding secondary breaker.
2. Main breaker: Supports 63A×3 at the main breaker interface, with built-in 300mA 10n residual current protection.
Popular Articles
How to use Smart CT Mode
Recent Articles
