What are the differences between the two communication ports on the device's chassis?
1.LAN port: Supports RJ45 network cable connections for direct linking to home routers.
2.COM Port: The COM port operates on the RS485 protocol, enabling connection with Zendure's Smart 3CT and future ecosystem products to achieve stable device coordination and precise power control.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
