What is the purpose of the RJ45 port on the device?
The RJ45 port supports RS485 communication and will enable real-time
RS485 communication with the upcoming Smart Meter 3CT-S / 1CT-S.
Popular Articles
How to use Smart CT Mode
Recent Articles
