How to view the energy consumption statistics of each load?
Slide down on the "Home" page of the Zendure APP to view the energy consumption statistics of each load; more detailed energy consumption charts for smart plugs can be viewed on their details page.
Popular Articles
How to use Smart CT Mode
Recent Articles
