How does a smart meter help achieve “zero energy waste”?
The smart meter dynamically adjusts power based on real-time household load,
matching electricity generation with consumption and avoiding energy feedback waste.
Related Articles
The smart meter dynamically adjusts power based on real-time household load, matching electricity generation with consumption and avoiding energy feedback waste.
How to use Smart CT Mode
How to use Smart Matching Mode
Smart Matching Mode is a Cloud-base feature, so you need to keep the SolarFlow and the ‘sensor’ devices have stable Wi-Fi connections all the time. Smart Matching Mode Introduce the function of Smart Matching Mode and its advantages and ...
How does a smart meter work?
A smart meter can monitor the household’s total electricity consumption and the direction of current in real time. When household power demand increases, it automatically raises the discharging power; when demand decreases, it lowers the output. This ...
Popular Articles
Recent Articles
