How to authorize and add Shelly's Smart CT to the Zendure APP?
1. On the 【Profile】 page, click the 【Shelly】 icon, jump to the embedded page, then click 【Authorize】, and log in to the Shelly account for authorization.
2. After successful authorization, jump back to the 【Device Selection】interface and select the Shelly CT to be added.
3. After successful addition, click 【Done】, and the newly added Shelly CT will be displayed in the device list.
    • Related Articles
    • How to use Smart CT Mode
    • How to authorize and add Shelly's relay to the Zendure APP?
      1. On the 【Profile】 page, click the 【Shelly】 icon, jump to the embedded page for authorizedlogin, then click【Add Device】, select the Shelly relay that needs to be authorized to control the heat pump,and click Confirm to add. 2. After returning to the ...
    • How to use Smart Matching Mode
      Smart Matching Mode is a Cloud-base feature, so you need to keep the SolarFlow and the ‘sensor’ devices have stable Wi-Fi connections all the time. Smart Matching Mode Introduce the function of Smart Matching Mode and its advantages and ...
    • How to add Smart Meter 3CT to the Zendure APP?
      Prerequisite for successful addition in the Zendure APP: having a Zendure Smart 3CT. 1. Open the APP, enter the device list, the 【Device Selection】 page will display the searching for devices, and then jump to 【Reset Wi-Fi】. 2. The page prompts to ...
    • Which smart meters or CT metering devices are supported?
      Supported metering devices include: Zendure Single-Phase CT, Zendure Three-Phase CT, Shelly Pro 3EM, Shelly 3EM, Shelly EM. Connection methods vary by device. Each device must be connected and configured according to the supported compatibility ...
    • Popular Articles
    • Why is my Hub’s battery light(AB1000 LED) turned off even though I have a battery connected to it?
      Check the battery status page of the Zendure App to see if all your connected batteries are recognized by the system. If no batteries are recognized, please contact support@zendure.com for further assistance. Please include a picture of the Zendure ...
    • Recent Articles
    • EVFlow AC Installation Official Tutorial Video
      EVFlow AC Official Video installation link: https://www.youtube.com/watch?v=QQ4JOUNW-30
    • What is EVFlow AC?
      EVFlow AC is a smart AC home EV charger provide 3 versions (7.4 kW, 11 kW, and 22 kW) When integrated with Zendure HEMS 2.0,it coordinates solar power, home energy storage, electricity tariffs, and household load management to optimize EV charging.
    • How should I clean and maintain EVFlow AC
      Inspect the charger, charging cable, and connectors for wear or damage approximately every six months. Before cleaning, disconnect the upstream power supply. Use a soft, slightly damp cloth to clean the enclosure. Do not use high-pressure water jets, ...
    • What should I do if charging does not start after plugging in the connector or the red fault indicator appears?
      First, check the following: Ensure the charging connector is fully inserted. Confirm that charging authorization has been completed. Check whether the vehicle or Zendure App has an active charging schedule limit. Verify that the selected charging ...
    • How can I identify the device status from the indicator light?
      Under normal operating conditions, green indicates online status, while blue indicates offline status. A solid light indicates standby mode, while a breathing light indicates that charging is in progress. When the breathing light changes to a solid ...
