Does it support EPS functionality?
Yes. When the device detects a grid power outage, it automatically switches to
supply power to loads connected to the AC off-grid port from the battery, providing backup power.
Related Articles
Yes. When the device detects a grid power outage, it automatically switches to supply power to loads connected to the AC off-grid port from the battery, providing backup power.
Does SolarFlow 1600 AC+ support powering household loads during a grid outage?
It features one off-grid outlet and supports off-grid output functionality. - Without additional battery modules, the maximum output power is 1400 W. - With additional battery modules, the maximum output power can reach 1600 W.
What is the current official support for heat pumps announced by Zendure?
At present, we support heat pumps compatible with SG ready, but the tests only cover two models of heat pumps: Viessmann Vitocal 250ah/Vaillant arotherm Plus. We do not guarantee complete functional effects for other heat pumps.
Does it support self-installed grid connection?
The SF2400 AC+ supports plug-and-play, user-installed grid connection. If you want to connect this product as a non-plug-and-play device to the distribution board to participate in feed-in tariff settlement, a certified electrician must hard-wire it ...
The SF2400 Pro supports plug-and-play, user-installed grid connection. If you want to connect this product as a non-plug-and-play device to the distribution board to participate in feed-in tariff settlement, a certified electrician must hard-wire it ...
Popular Articles
How to use Smart CT Mode
Recent Articles
