What is the function of the PV OFF knob?
The SolorFlow4000Mix Pro DC-side circuit breaker is integrated within the inverter unit, featuring both mechanical operation and electrical control capabilities. Since the photovoltaic side may remain energized continuously during sunlight exposure, the PV system must be shut down before connecting, maintaining, or installing/disassembling solar panels to enhance installation and maintenance safety.
Popular Articles
How to use Smart CT Mode
Recent Articles
