How to enable the PV-IN AC control function?
The port is closed by default; go to the APP settings page and turn on the PV-IN AC switch.
Related Articles
How to enable the AC off-grid port output?
The off-grid AC port is disabled by default before activation. You can enable it in two ways: 1. Enable the feature in the Zendure App before use. 2. By double-clicking the IoT button, you can manually switch AC off-grid sockets on-site even without ...
Does the equipment support MPPT PV input function?
The SolorFlow 3000Mix AC+ does not have an MPPT input function, which is one of the core differences from the 4000Mix series.
How to activate the AC off-grid port output function?
The off-grid AC port is disabled by default. There are two activation methods: ① Enable it through the Zendure App; ② In scenarios without network or App, press the power button twice consecutively to manually switch on/off locally.
Popular Articles
How to use Smart CT Mode
Recent Articles
