What functional settings are supported?
1. After the user adds the Shelly relay connected to the heat pump to the Zendure App,
the user can rename the relay and modify its icon for selection in HEMS.
2. The user unbundles the binding relationship between the Shelly relay and the Zendure App;
(Shelly relay model:Shelly Pro 2 or Shelly Plus 2PM ).
3. The user changes the type of load associated with the relay; (Change/unbundle the load associated with the relay).
4. The user changes the associated Smart CT. (Change/unbundle the Smart CT and its sub-circuits associated with the relay)
Popular Articles
How to use Smart CT Mode
Recent Articles
