Can something go wrong during the switch so that the electricity supply is interrupted?
No. The switch happens seamlessly, so that we supply you directly after your old contract ends. Even if there were problems, continuous electricity supply is ensured by the statutory basic supply.
Popular Articles
How to use Smart CT Mode
Recent Articles
