Two categories of items are required:
1.Cables: 3-core outdoor copper cable (6mm² cross-section), PE wire (≥6mm², recommended length ≥3m), RJ45 network cable (same length as power cable, for main unit to CT connection), 32A circuit breaker;
2.Tools: Cable cutter, wire stripper, insulating tape, rubber gloves, heat gun, heat shrink tubing, electric drill, M4 Phillips/slotted screwdriver, O-type terminals.
