When the "Surplus Energy" logic is triggered, how does the system activate loads?
It checks devices in descending order of priority. A load is activated only if its starting power ≤ available surplus power, operating at the minimum power required to consume the surplus. If there is still surplus (>100W), the next priority load is activated to minimize power drawn from the grid.
Related Articles
What is the maximum number of energy storage devices connectable to the Schuko sockets of the Zendure PowerHub 1P, and what specifications are required?
Up to 3 sets of energy storage devices can be connected, compatible with models such as 4000 Mix/AC+ and SF2400 Pro with grid-tie power ≤3680W.
What is the maximum number of energy storage devices connectable to the Schuko sockets of the Zendure PowerHub 3P, and what specifications are required?
Up to 3 sets of energy storage devices can be connected, compatible with models such as SolarFlow 4000 Mix Pro /AC+ and SolarFlow2400 Pro with grid-tie power ≤3680W.
What are the two connection methods for energy storage inverters supported by the Zendure PowerHub 3P, and their applicable scenarios?
There are two connection types: Schuko plug-and-play and hardwired. The Schuko method is for grid-tie inverters ≤3680W, while hardwired is for units >3680W.
What are the two connection methods for energy storage inverters supported by the Zendure PowerHub 1P, and their applicable scenarios?
Popular Articles
How to use Smart CT Mode
Recent Articles
