What should I do if I use the hotspot mode to configure the network but still cannot connect to the APP?
If the device does not connect to any WiFi hotspot from the router, but tries to connect to the WiFi hotspot from the mobile phone or laptop, but SuperBase Pro still cannot connect to the APP, please refer to the following solutions:
1. You need to reset the device to the hotspot configuration mode correctly;
2. Use a mixing network of 5Ghz and 2.4Ghz, or a 2.4Ghz network, if the connected network is only 5Ghz, it cannot be connected;
3. Connect the correct Wi-Fi hotspot on the phone Wi-Fi settings page (the hotspot name of the device usually starts with "SmartLife");
4. Make sure the phone is fully connected to the device's hotspot before returning to the App;
5. Some mobile phone systems will mistake the hotspot network of the device as an unsafe network, so it cannot be connected, and you need to set it in the phone settings to connect;
6. If the connection process is stuck in the "register to the cloud" step, it may be that the compatibility between the device and the router is not good;
7. If you still cannot connect and operate the device through the above methods, it may be a hardware problem of the device. Please contact Zendure's technical support directly.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
    • Recent Articles
    • Important Checks Before Connecting PV Modules
      Before connecting PV modules, please verify the following items to ensure safe and stable operation of the unit: PV module specifications (e.g., open-circuit voltage Voc) are within the permissible operating range of the device. Each PV input (MPPT) ...
    • Important Checks Before Connecting PV Modules:
    • Will SolarFlow 800 Pro 2 supply power during a power outage?
      According to EU safety regulations, the SolarFlow 800 Pro 2 will stop supplying power to the grid during a power outage; However, you can use the off-grid outlet during power outage with max 1000W power.
