What should I do if charging does not start after plugging in the connector or the red fault indicator appears?
First, check the following: Ensure the charging connector is fully inserted. Confirm that charging authorization has been completed. Check whether the vehicle or Zendure App has an active charging schedule limit. Verify that the selected charging strategy meets the conditions required to start charging.
If the red fault indicator appears, check the error message in the Zendure App and contact technical support.
If you notice damage to the enclosure or charging cable, water ingress, or abnormal overheating, stop using the charger immediately. Disconnect the upstream power supply if it is safe to do so, and contact a qualified electrician for repair.
