What should be noted before installing the expansion battery?
1. A single host can connect up to 5 sets of expansion batteries (maximum total capacity of 11.52kWh);
2. Do not disconnect during the charging and discharging process;
3. Do not touch the metal contacts. If you need to clean, please use a dry cloth;
4. It is recommended to use the matching bracket and screws to ensure stable stacking.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
