What is the start and stop logic of the plug-and-charge function of EVFlow AC?
In Non-Plug & Play mode, the system does not automatically close the relay after plugging in.  Charging must be authorized via a local RFID card swipe or triggered through the mobile App either in close proximity (Bluetooth) or remotely (Wi-Fi/Ethernet via MQTT). Once account credentials are confirmed, the internal relay closes to supply power.
When the vehicle is fully charged, the relay automatically disconnects power output. If you need to disconnect the charging cable, stop charging via an RFID card swipe or through the App first; hot-unplugging during active charging is not supported.
