What do I have to pay attention to when storing solar modules?
Solar modules must be stored at room temperature and a humidity of no more than 60 %.
Related Articles
How many years is the warranty for solar modules?
The component warranty for solar modules is 12 years.
Can I combine different types of solar modules?
We do not recommend mixing different solar modules. To get the most efficient solar module system, we recommend that you use solar modules of the same brand and type.
Why the solar modules do not reach the rated power of 210 W?
There are a number of factors that cause solar modules not to reach their rated output, such as weather, light intensity, shading, orientation of solar modules, ambient temperature, location, etc.
Can 210W Flexible Solar Panel be connected in parallel?
Yes Connecting solar modules in parallel doubles the current and thus improves the performance. The maximum number of 210W Flexible Solar Panel connected in parallel depends on your microinverter and energy storage. Make sure your microinverters ...
Important Checks Before Connecting PV Modules:
Before connecting PV modules, please verify the following items to ensure safe and stable operation of the unit: PV module specifications (e.g., open-circuit voltage Voc) are within the permissible operating range of the device. Each PV input (MPPT) ...
Popular Articles
How to use Smart CT Mode
Why is my Hub’s battery light(AB1000 LED) turned off even though I have a battery connected to it?
Check the battery status page of the Zendure App to see if all your connected batteries are recognized by the system. If no batteries are recognized, please contact support@zendure.com for further assistance. Please include a picture of the Zendure ...
Recent Articles
EVFlow AC Installation Official Tutorial Video
EVFlow AC Official Video installation link: https://www.youtube.com/watch?v=QQ4JOUNW-30
What is EVFlow AC?
EVFlow AC is a smart AC home EV charger provide 3 versions (7.4 kW, 11 kW, and 22 kW) When integrated with Zendure HEMS 2.0,it coordinates solar power, home energy storage, electricity tariffs, and household load management to optimize EV charging.
How should I clean and maintain EVFlow AC
Inspect the charger, charging cable, and connectors for wear or damage approximately every six months. Before cleaning, disconnect the upstream power supply. Use a soft, slightly damp cloth to clean the enclosure. Do not use high-pressure water jets, ...
What should I do if charging does not start after plugging in the connector or the red fault indicator appears?
First, check the following: Ensure the charging connector is fully inserted. Confirm that charging authorization has been completed. Check whether the vehicle or Zendure App has an active charging schedule limit. Verify that the selected charging ...
How can I identify the device status from the indicator light?
Under normal operating conditions, green indicates online status, while blue indicates offline status. A solid light indicates standby mode, while a breathing light indicates that charging is in progress. When the breathing light changes to a solid ...
