Why is my Hub’s battery light(AB1000 LED) turned off even though I have a battery connected to it?
Check the battery status page of the Zendure App to see if all your connected batteries are recognized by the system.
If no batteries are recognized, please contact support@zendure.com for further assistance. Please include a picture of the Zendure App’s battery status page in your message.
If some batteries are recognized and some are not, rearrange your system so that only the recognized batteries are physically connected to the system and see whether the battery light on the Hub illuminates.
If the light comes on and the other batteries are recognized and working, please contact the dealer who supplied the non-functioning battery/batteries and provide them with any relevant serial numbers for further assistance.
If none of the batteries in your system are being recognized after following the above steps, please contact the dealer who supplied your SolarFlow system and provide them with your Hub’s serial number for further assistance.
    • Popular Articles
    • How to use Smart CT Mode
    • Why is my Hub’s battery light(AB1000 LED) turned off even though I have a battery connected to it?
      Check the battery status page of the Zendure App to see if all your connected batteries are recognized by the system. If no batteries are recognized, please contact support@zendure.com for further assistance. Please include a picture of the Zendure ...
    • Recent Articles
    • EVFlow AC Installation Official Tutorial Video
      EVFlow AC Official Video installation link: https://www.youtube.com/watch?v=QQ4JOUNW-30
    • What is EVFlow AC?
      EVFlow AC is a smart AC home EV charger provide 3 versions (7.4 kW, 11 kW, and 22 kW) When integrated with Zendure HEMS 2.0,it coordinates solar power, home energy storage, electricity tariffs, and household load management to optimize EV charging.
    • How should I clean and maintain EVFlow AC
      Inspect the charger, charging cable, and connectors for wear or damage approximately every six months. Before cleaning, disconnect the upstream power supply. Use a soft, slightly damp cloth to clean the enclosure. Do not use high-pressure water jets, ...
    • What should I do if charging does not start after plugging in the connector or the red fault indicator appears?
      First, check the following: Ensure the charging connector is fully inserted. Confirm that charging authorization has been completed. Check whether the vehicle or Zendure App has an active charging schedule limit. Verify that the selected charging ...
    • How can I identify the device status from the indicator light?
      Under normal operating conditions, green indicates online status, while blue indicates offline status. A solid light indicates standby mode, while a breathing light indicates that charging is in progress. When the breathing light changes to a solid ...
