Why isn’t my battery charging?
Step 1: Please go to the battery status page of the Zendure App and identify the battery that isn’t charging. If you have multiple batteries in your system, rearrange your configuration so that only the battery that isn’t charging is connected to your system. Using the Zendure App, set the battery’s charging limit to 100% and the discharge limit to 0%. This may resolve the issue;
Step 2: If the battery still isn’t charging all the way, please contact the dealer who supplied your SolarFlow system for further assistance. They will need the serial number of the relevant battery.
Popular Articles
How to use Smart CT Mode
Why is my Hub’s battery light(AB1000 LED) turned off even though I have a battery connected to it?
Check the battery status page of the Zendure App to see if all your connected batteries are recognized by the system. If no batteries are recognized, please contact support@zendure.com for further assistance. Please include a picture of the Zendure ...
Recent Articles
EVFlow AC Installation Official Tutorial Video
EVFlow AC Official Video installation link: https://www.youtube.com/watch?v=QQ4JOUNW-30
What is EVFlow AC?
EVFlow AC is a smart AC home EV charger provide 3 versions (7.4 kW, 11 kW, and 22 kW) When integrated with Zendure HEMS 2.0,it coordinates solar power, home energy storage, electricity tariffs, and household load management to optimize EV charging.
How should I clean and maintain EVFlow AC
Inspect the charger, charging cable, and connectors for wear or damage approximately every six months. Before cleaning, disconnect the upstream power supply. Use a soft, slightly damp cloth to clean the enclosure. Do not use high-pressure water jets, ...
What should I do if charging does not start after plugging in the connector or the red fault indicator appears?
First, check the following: Ensure the charging connector is fully inserted. Confirm that charging authorization has been completed. Check whether the vehicle or Zendure App has an active charging schedule limit. Verify that the selected charging ...
How can I identify the device status from the indicator light?
Under normal operating conditions, green indicates online status, while blue indicates offline status. A solid light indicates standby mode, while a breathing light indicates that charging is in progress. When the breathing light changes to a solid ...
