What are the requirements for the installation environment?
1. The device can be installed indoors or outdoors, but direct sunlight and rain exposure should be avoided.
2. Ensure that the device is within Wi-Fi coverage.
3. Leave at least 15 cm of space above the unit and at least 5 cm of ventilation space at the rear.
4. The installation location must be within the length range of the PV cables and the 3 m AC power cable.
5. Keep the device away from flammable or explosive materials.
6. Place the device on a stable and solid surface.
    • Related Articles
    • What are the requirements for the installation environment?
      It can be installed indoors or outdoors, but avoid direct sunlight and rain. Ensure the device is within Wi-Fi coverage. Reserve ≥5cm space on top and ≥15cm ventilation distance at the back. The installation location needs to be within the range of ...
      1. The device can be installed indoors or outdoors, but direct sunlight and rain exposure should be avoided. 2. Ensure that the device is within Wi-Fi coverage. 3. Leave at least 15 cm of space above the unit and at least 5 cm of ventilation space at ...
    • SolarFlow 1600 AC+ Installation Manual
      Video Link: FR:Installation complète du SolarFlow 1600 AC+ : du déballage au mode hors réseau - YouTube NL:SolarFlow 1600 AC+: volledige installatie – van het uitpakken tot de off-grid-modus EN: https://www.youtube.com/watch?v=e1HQqSp9tnw DE: ...
    • SolarFlow 2400 Pro Installation Manual
      Video link: EN: https://www.youtube.com/watch?v=X307oOWnYZI DE: https://www.youtube.com/watch?v=7qATOYRR6Bc FR: https://www.youtube.com/watch?v=N3cQ1WDFSI0 NL: https://www.youtube.com/watch?v=PAbmGMwHOh8
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
