What are the RCD configuration requirements for upstream and downstream circuits during the Zendure PowerHub 1P installation?
Built-in 300mA residual current protection eliminates the need for an additional upstream independent RCBO. Downstream circuits must be equipped with 30mA RCD protection per local regulations (either individually per branch or shared across multiple branches).
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
